Engine Pulse Vibration
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
For the passed week I've noticed an odd "pulse/vibration/studder/surge?" Coming from the engine at idle. While sitting idle I can feel a random vibrational pulse through the entire vehicle including steering wheel and seat. Sometimes I feel it once every 30 seconds and sometimes multiple times in rapid succession. The tachometer never changes. RPM confirmed through OBDII reader. Stays right at 800 or 840. No CEL, no stored codes. Happens independent of AC engagement. Its too subtle for i misfire i would think. Its very strange. Although I've never heard what detonation sounds like, it's on the list?
Thoughts?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Check for DTC codes.
Clean out the IAC Valve ( Idle Air Control Valve ).
Check for Air leaks in the Intake side.
Active
Past
ZionXIX
Post by ZionXIX »
Codes are clear
I just replaced the intake hose attached to the throttle and the IAC a few weeks ago. It was very clean inside. I guess I need to find my rigged smoke tester for the intake.
