I have the B4164S2 engine, compression in all cylinders is equally low, at 60PSI cold and 120 hot, test was done with WOT. All the cylinders measure the SAME compression. The symptoms are a general lack of power. The engine is rated at 109hp, but it's probably half that.
Squirting oil(two full tablespoons or more, not teaspoons) brings it up to about 150 PSI, again it's absolutely the same for all cylinders.
It's either valves, worn rings or stuck rings. So I will try a piston soak as a last resort for stuck rings with Kerosene-based solvents and Acetone-based solvents mixed together, cause in Eastern Europe we don't have Seafoam,Marvel Mystery Oil, Kreen or B-12 Chemtool. It will either work or it will not. If it doesn't, it's likely not stuck stuck rings, but either worn or bad exhaust valves and/or worn piston rings. Recently replaced the belt, had 2 skipped teeth on exhaust cam, but after fixing this the compression did not move at all.
Car has 155+k miles on it, though it could be more as odometer rewinding is extremely common over here.
Before anyone mentions PCV, yeah mine was clogged and had a broken diaphragm for nearly 2 years, so we replaced it with an open-tube system, the blowby gets out.
If this doesn't work, I've prepared thicker 10w50 oil to try.
Piston soak for rings.
- RickHaleParker
- Been thanked: 977 times
Homebrew Sea Foam (SeaFoam) Motor Treatment Recipe.jakeb123 wrote: 02 Oct 2020, 10:24 cause in Eastern Europe we don't have Seafoam,Marvel Mystery Oil, Kreen or B-12 Chemtool.
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1075 times
It is interesting that all cylinders are the same for all compression tests. You would expect some variation in condition.
- RickHaleParker
Makes one wonder if he is at a high altitude.volvolugnut wrote: 02 Oct 2020, 17:50 It is interesting that all cylinders are the same for all compression tests. You would expect some variation in condition.
Active
Past
Past
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
What's your oil consumption?
Does the engine miss at idle? Will it even idle?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
It idles just fine. It has always started consistently without any issues. I have not measured oil consumption but I have added numerous additives to thicken the oil, so it has subsided, before if I fill it to the max on the dipstick, it would go to the half within 1000km, where it would stop or drop very very slowly.
I did the soak for 12 hours and noticed it had all drained. I added some more and left it there and noticed it had drained within less than 2 hours. I measured compression, nothing. No change I think.
Another thing I must mention, when I rev the engine and let go of the gas, as the engine decelerates there is some muffled pop-back occurring. If I add a piece of cloth, my god does it get sucked in. I've heard that an exhaust leak can cause this, as I have a broken flex pipe, but if it isn't the culprit, then it's valves.
- 1074 Views
Last post by Cees Klumper
- 12 Replies
- 2693 Views
Last post by Khorn09
- 404 Views
Last post by Sveedy
- 1156 Views
Last post by Kokonradus
- 40 Replies
- 22106 Views
Last post by GDiode
