Odd 850 no start issue
BatStig
Year and Model: 1997 850 GLT
Has thanked: 7 times
Post by BatStig »
This is a bit long winded, so my apologies up front.
I recently purchased a 1997 Volvo 850 GLT. It has a 15G turbo and an ECU from Vast Tuning. I burnt a valve on my 4500km drive home and have since had the cylinder head rebuilt. I put the car back together and she ran well. I flashed a new tune from Vast onto the car and did some logging. I then flashed another tune and then she cranked but wouldn't start. I have no spark. Fuel squirts out when I push the Schraeder valve on the fuel rail. I flashed back to the previous tune. Still no spark. I replaced the spark plug wires, distributor cap and rotor, as well as the cam position sensor. Still no spark. I got my hands on an ECU from a scrapyard. Not the correct one, 0 261 203 072 ('95 T5?), but it's an ECU. With the scrapyard ECU the car has spark and will start but won't idle unless I keep my foot on the gas. Vast sent me another ECU. I just installed it and still have the same problem; crank but no start. I was about to check for spark again, but it has started to rain. I will be heading back out as soon as it stops.
Does anyone have any suggestions on what I should do next? I am at a loss here. Any help you can provide would be greatly appreciated.
Thank you.
New info: flashed a stock tune onto the Vast ECU and it behaves like the scrapyard ECU: the plugs are now sparking and it starts but won't idle/stay running if I take my foot off the gas.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Are the tunes you're flashing all VAST tunes?
BatStig
Post by BatStig »
Chuck W wrote: 02 Oct 2020, 17:55 Are the tunes you're flashing all VAST tunes?
Yup. Straight from Aaron. He said that he double checked the files and everything is okay.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The last ECU from VAST, did you flash onto it or just popped it in as you received it? Wondering if it could be a problem with your flashing rig somehow corrupting the file/ECU.
BatStig
Post by BatStig »
erikv11 wrote: 02 Oct 2020, 18:46 The last ECU from VAST, did you flash onto it or just popped it in as you received it? Wondering if it could be a problem with your flashing rig somehow corrupting the file/ECU.
The previous owner had installed a VAST ECU. I flashed it once and it ran fine. I flashed it a second time and then there was no spark. I flashed the previous tune and still no spark. VAST sent a new ECU and again no spark. I had him also send one of his VAG COM cables just in case my cable did something stupid. He resent the tune and I flashed it with his cable. Nothing.
Has thanked: 2200 times
Been thanked: 1852 times
Is the engine turning over but just not firing? It could be the immobiliser not sending a spark.
Couple of simple things to try:
1) Disconnect the battery and touch the leads. This resets the electrical system.
2) Re-connect the battery, +ve lead first.
3) Manually lock/un-lock the drivers' door lock with the key in the door lock.
BatStig
Post by BatStig »
scot850 wrote: 03 Oct 2020, 12:27 Is the engine turning over but just not firing? It could be the immobiliser not sending a spark.
Thanks. I will give this a try.
I will also add new information. Vast sent me a stock tune and it now has spark. With the stock tune it behaves the same as the scrapyard ECU; it starts but will not idle/stay running if I take my foot off the gas.
Chuck W
Post by Chuck W »
Sounds like something corrupt in the tunes.
What injectors are on the car? Any other mods besides the turbo and ECU?
BatStig
Post by BatStig »
Chuck W wrote: 03 Oct 2020, 14:14 Sounds like something corrupt in the tunes.
Orange injectors, which Vast is aware of. Other mods? Nothing to do with the engine. Exhaust. Suspension. That's it.
Chuck W
Post by Chuck W »
What are the last 3 digits on the ECU you're flashing?
