I have a B5254S engine.its a 1994 ok well it seems all good, but looking it up, did I come off the assembly block at the end of the year, bc B5254S is starting at 1995. I'm a bit confused, is it 2.3, 2.4 what do I have? When I order parts some will say that won't work,and what they say will work is more expensive, but many things do work. Can someone please explain. Do I have a 94 95 Volvo wagon? 2.3 or 2.4
Thank you
What's my Volvo wagon
- Has thanked: 1836 times
- Been thanked: 1709 times
According to Wikipedia it is a 20V 2.5 used from 91-95.
Some confusion is caused by different model years in Europe. When I was in the UK, the car year was based on when it was made or registered for the first time.
https://en.wikipedia.org/wiki/Volvo_850
94-95 in North America is an awkward change over year from headlights to electronics.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Model year changes often occured mid-year. This wasn't to do with the countries, just happened to be when the tooling and changes were implemented in different factories. My Belgian made 850 was manufactured September 95, but is a MY96 car - because the equipment and tooling for the MY96 facelift arrived at the factory in August.
The important thing to look for is the engine code, which only shows one result. A 2.5 20v as Neil says. As Neil also states, the B5254S was used from 91-95, which would seem to remove some confusion from your post.
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
I'm ordering 2.4 I guess I will see what gives going 2.5 when need be, I know the beetles and the super beetles did the same thing if it came off the line in October, it was the next year's model. Thanks
- 1216 Views
Last post by Fred Trotman
- 826 Views
Last post by manovlov
