240 tripometer
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
markvt
240 tripometer
Post by markvt »
Had the reset button on the 240 tripometer fall off. It just became loose and would pull completely out. I know it had a spring behind it originally. The question is: if I pull the instrument cluster will I be able to reach this reset button and maybe "super glue" it back in?
Thanks,
Mark
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If you were to superglue it back in it is highly likely that it will stick to the housing as well, thus making it inoperative. Also do you have the spring?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
markvt
Post by markvt »
Bill,
I haven't pulled the thing apart yet. I assume that the spring is still inside. I had planned to put a dab of super glue on the end of the button and let it dry so I don't think it will stick on the housing. I was mainly asking that if I pulled it apart would I be able to get to the area it attaches to so that I could hit it with the glue or is is an enclosed housing that can't be accessed without a hammer:-)
mark
billofdurham
Sorry, I misread that one. It is easy to open up the panel and, looking at the VADIS diagram. it should be relatively easy to glue it back together.
There is no mention of a spring in the parts list, but perhaps they did not expect them to come apart.
This is the only speedo I can find for a '92 240. Hope it helps.
Bill.
Previously:
markvt
Post by markvt »
Thanks, when I get a break in the weather I'll pull it apart.
Mark
