timing belt components
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
I replaced the timing belt kit (except the water pump at 156K ). Now at 189K, I noticed a small leak on the pump. Can I replace just the pump? The rest of the components are 33K young
. The pump is original.
januwan
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes you can.
Use ONLY Aisin or SKF water pump.
Just make sure that you remove ALL of the old water pump gasket.
However...you will need to remove timing belt and set timing again after water pump replacement.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
You can, and you might as well just toss a new belt on there while you're in there.
However, that engine *should* have the hydraulic tensioner, and you will need to remove it and S-L-O-W-L-Y compress it and lock it with the pin before you go to reinstall the timing belt.
- Has thanked: 311 times
- Been thanked: 817 times
The hydraulic tensioner can confidently go two timing belt intervals i.e. 150k. Chuck is just explaining how to reuse it. Unless the tensioner has high miles save some $ and leave it.
- Chuck W
The only issue with re-use is if you're on a time crunch, as you can't speedily force it back to its "home" position.erikv11 wrote: 27 Oct 2020, 21:31 The hydraulic tensioner can confidently go two timing belt intervals i.e. 150k. Chuck is just explaining how to reuse it. Unless the tensioner has high miles save some $ and leave it.
- 13 Replies
- 5473 Views
- 5271 Views
Last post by jimmy57
- 23 Replies
- 17189 Views
Last post by jonesg
- 20 Replies
- 17439 Views
Last post by Hurtfeelings
- 1971 Views
Last post by Juan62
