Cam alignment issues after cam seal replacement
dad2three
- Year and Model: 99 V70 GLT
- Has thanked: 3 times
Question for those much more experienced than I with setting timing belts on a 99 2.4 LPT w/ VVT. I needed to replace cam seals so did the whole job with timing belt and water pump. I set the VVT hub as per Vida- bring outer ring to CW limit, align with mark 1 cog before the mark, tighten to 88 ft/lbs making sure it doesn't move. I get the timing belt on and tensioned, remove the cam locks, and rotate the crank. My marks all align, but my exhaust cam is rotated further forward about the thickness of the lock tab on the cam lock. This result is consistent no matter how many times I remove and reset the belt. Any ideas/suggestions?
Darrin
99 V70 GLT
99 V70 GLT
dad2three
I’ve tried 3 different ways of setting the vvt hub (Vida, one I found on MVS, and another way described on Swedespeed). I’m thinking that the hub may be messed up so I’m installing a new vvt hub today.
Darrin
99 V70 GLT
99 V70 GLT
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
It's going to do some crazy stuff without oil pressure regulating it. If it isn't making contact with the valves, fire it up at idle and see if she codes. I believe we found that the tolerance for the ECU is about a tooth or so in either direction. Abscate and I just worked on one of these, he may be able to give details and possibly even pictures.dad2three wrote: 30 Oct 2020, 12:44 Question for those much more experienced than I with setting timing belts on a 99 2.4 LPT w/ VVT. I needed to replace cam seals so did the whole job with timing belt and water pump. I set the VVT hub as per Vida- bring outer ring to CW limit, align with mark 1 cog before the mark, tighten to 88 ft/lbs making sure it doesn't move. I get the timing belt on and tensioned, remove the cam locks, and rotate the crank. My marks all align, but my exhaust cam is rotated further forward about the thickness of the lock tab on the cam lock. This result is consistent no matter how many times I remove and reset the belt. Any ideas/suggestions?
- 9620 Views
Last post by tyguyc
- 22 Replies
- 10386 Views
Last post by ggleavitt
- 18 Replies
- 3791 Views
Last post by jwegman
- 1483 Views
Last post by iRenaissanceMan
- 828 Views
Last post by SomeYahoo
