Fuel injectors
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Fuel injectors
Hi guys, I pulled some fuel injectors out of an 850 yrs. ago at the JY. Mine are in need of a cleaning.if I clean the ones out of the junk yard will I have a tuning problem or should I practice the cleaning on the JY ones and then do the ones that are in my car. I'm a little confused about the fuelinjector tuning and all that,.any helptips will be GREATLY Appreciated. Thanks
- Has thanked: 2652 times
- Been thanked: 1245 times
Contact Michael Jingle. https://www.facebook.com/JingleMichael He refurbs injectors.
He's this guy https://www.matthewsvolvosite.com/gorge ... gon-build/
- misha
- Has thanked: 152 times
- Been thanked: 402 times
If they have the same Bosch numbers on it and have the same color...it's a direct swap.
But....if they were unprotected all those years....they will need cleaning before install.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
loveMy850
Thanks they are a different color and a bit smaller thought I'd practice cleaning them. Do you think those small self cleaning kits for 14$ is worth it. I tried making my own but the darn thing kept coming off on the tire cap I was using. Oh well... TY
- misha
In that case....i wouldn't install them.
You will need injectors with same Bosch numbers and color.
They may have higher or lower flow rate...different resistance....and engine would not run properly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
So yeah, if a 14 dollar kit allows you to practice before you tackle your primary set, spend and tear 'em down and build 'em up a couple times, then do it for real on the set that came in your car. Or have them commercially serviced. Depending on where you are in CA may be easy and cheap(ish)
Current Volvos:
loveMy850
Agree.... I'll do it myself, I did however pulled my injectors and cleaned them, not inside but I took a soft brass brunch and cleaned the tips, lots of carbon build up. Just doing that my babys feel much better... ( :
- 289 Views
Last post by pinegrovedave
- 1487 Views
Last post by 93Regina
