Post your pictures here!
Ok, I’m getting ready for the big one...warmupfrom years past...
P80 cars in the snow
- Been thanked: 4067 times
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Well this is really cool! Do you mind me asking what kind of engine block heater you are using?
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 311 times
- Been thanked: 817 times
With pics viewtopic.php?t=68260
S60UT
- Year and Model: 2000 V70R
- Been thanked: 4 times
The storm, heading your way only dumped a few inches here in UT so not enough to post a good pic. Guess you guys are gonna get hammered when it mixes with warm air from the south, I look forward to seeing some cool pics from you NorthEastern folks. Make sure that snow blower carb is cleaned and ready to go !abscate wrote: 16 Dec 2020, 05:03 Post your pictures here!
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
00 V70R
99 V70 T5
09 FX35 Clown shoe
16 Jetta GLI
- Has thanked: 987 times
- Been thanked: 1075 times
Rumor says you have a T5 powered snow blower in your garage ready for this storm.abscate wrote: 16 Dec 2020, 05:03 Post your pictures here!
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
From 2011, but still one of my favorite pics of my XC.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2200 times
I like the silicon oil pan heaters or even the water heaters that fit in the water pipes. The Volvo one does work but has to be left on for a long time. Strangely Canada has a lot of variety of heaters including heaters you can sit under the car engine bay that are pretty inefficient but do warm a large area.
I did pull some Volvo block heaters a couple of years ago (as I suggested I might in the linked thread) and managed at that time to find new leads for some of them as some were a little worn on those I pulled. The neat thing on the Volvo ones is they are fitted on a swivel bracket that fits behind the lower edge of the hood on the cross member. It means it is hidden and protected when not needed.
The bigger issue was to use thermal paste when fitting the Volvo one between the block and the heater. Again I managed to find some on line conveniently supplied in tubes. Now if I only can ever get the stuff out of storage I can share more info. I think I even had a P2 version!
I have mentioned it before, if it is constantly below 32F (0C) it is worth fitting a piece of cardboard behind the hood grill with zip-ties, in particular with turbo engines to reduce the likelihood of the intercooler freezing.
I've only iced the throttle body once. I was in 10-15F in slow 15-25 traffic in PVD three hours ft home. Started getting ETS light. Once I got back up to 50 mph and light boost it all cleared up
Update. Still no snow. Forecast to start 2300
- 707 Views
Last post by boltthrower
- 12 Replies
- 2628 Views
- 456 Views
Last post by foggydogg
- 14 Replies
- 1779 Views
- 595 Views
Last post by erikv11
