V70 Problem
V70 Problem
1998 V70 T5 has stopped running. Will start but dies after 10-15 seconds. Replaced the fuel pump, fuel filter, camshaft and crankshaft sensors. Also cleaned the mass air sensor with the appropriate cleaner. Problem persists.
- Has thanked: 928 times
- Been thanked: 1002 times
More information please. What is the miles and general condition of the engine? Will the engine restart immediately after it dies? Do you do anything to the car before the problem started (changes to wiring, fuel system, other)? In the 10-15 seconds of running, does the engine surge and can you increase engine speed with throttle opening? Can you have check fuel pressure on the fuel manifold at the injectors?
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Fuel pump relay?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
