1998 v70 AWD dome light problem, locks problem Help needed
vernsimports
- Year and Model: 1998 v70awd
I am unable to find a list of component numbers [ ie 2/75 or 7/39 ] with actual name of component . 1998 V70AWD
- Has thanked: 987 times
- Been thanked: 1076 times
Are these component numbers from an electrical schematic? They sound like they are.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
That's how those read to me also, pin and connector ids from schematic. What are you troubleshooting ( in mechanical terms)
Current Volvos:
vernsimports
Yes, electrical components . Have 3 issues , interior [ dome light ] does not shut off when doors are closed . Must switch off at dome light .
power door locks do not work with remote . Battery goes dead if left connected for several days .
Battery works fine in my S70 , so not the battery .
I am retired from my VOLVO shop now 12 years, so not a lot of experience with P80 electrical issues .
vernsimports
Dome light assembly works fine in my S70 . Have several proper remotes but none work .
Might add, I have the AUTODIAGNOS MULTITESTER PRO which is what we used at the VOLVO dealership .
- Has thanked: 1611 times
- Been thanked: 4071 times
I dont think the component numbers are preserved across model years, but 2/76 is the lock controller and 3/79 is the antenna ring in 1999. The component family 2/xxx will be preserved.
If you are having trouble with the courtesy lights coming on, there is a painful thread on that in this forum with 2/76 part number in the title.
No children should be in the room while it is being read.
vernsimports
Thanks ! Could the dome light issue and the door locks be connected ? I see several microswitches in door latch . Surely one tells the dome light that the door is closed ?
Everything sends signals to the lock controller, which then grounds the lights through a power transistor
It’s a nasty complex system
vernsimports
Thanks, tried 2/76 thread search , but it was not found . How do I search thread for 2/76 ?
This is for a 1999 so the system is different, but gives an idea of the complexity
viewtopic.php?p=498565#p498565
- 2491 Views
- 1615 Views
Last post by CIK7
- 404 Views
Last post by rspi
- 3817 Views
Last post by Seaway
- 978 Views
Last post by jefflamonica
