will my 92 240 engine swap into my 92 740?
swells95126
- Year and Model: 1992 240
will my 92 240 engine swap into my 92 740 with out problems? Thanks for your help.
swells95126
oh I forgot the 240 is a sedan and the 740 is a wagon. Thanks
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
The 740 was an update to the 240. I think the 700s are built off of the 200 series. They're similar engines. I don't see why they would make a different mounting set up. Advice: measure everything needed in the engine bay to determine if it is the same.
If you think about it, Volvo has made a lot of vehicles interchangeable. 850 and 70 series engine can be swapped from one sedan and/or wagon. I think the early 90s 960 straight-6 can swap into the late 90s 960 and 90 series sedan and wagon. Someone correct me if I'm wrong on that.
If my p80 parts customer wanted to remove his S70's (sedan) solid rear axle and install my v70's (wagon) AWD rear axle, he could because the s70 was prepped same way AND some s70s were equipped with AWD.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
The 240 most likely has a block mounted distributor and the 740 most likely has a head mounted distributor. The auxiliary shaft may need to be swapped over. It would be a lot simpler if they both happen to have block mounted distributors.
1988 Volvo 760 Turbo Wagon
- 1202 Views
Last post by matthew1
- 844 Views
Last post by erikv11
- 2272 Views
Last post by buhao
- 848 Views
- 2003 Views
Last post by firstv70volvo
