Noise on accelerating left turn....wheel bearing? Topic is solved
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
For about the past 4 months I've been experiencing a noise that occurs when I am turning left and accelerating, like on an onramp or normal left turn from a traffic light. Turning and coasting doesn't make the noise, only while accelerating and turning left. I would describe the noise as: buzzing like a Dremel tool, or like a power steering pump running dry. The noise goes away after the turn forces neutralize, or if I get off the gas pedal. Any Idea what the problem might be?
2003 XC 70 (sold)
Blacklab467
Boy do I feel stupid! Turns out it was the power steering fluid level, when it's on low a long left turn, the pump will starve of fluid because of the lateral design of the reservoir. I should have known! The noise sounded major and had me worried about something more serious like a wheel bearing or something inside the transmission. Now is a good excuse to go out and flush the power steering fluid like I had planned to for the last few months.
2003 XC 70 (sold)
Has thanked: 1609 times
Been thanked: 4065 times
Low roar for the wheel bearing, not like a Dremel
