1996 850R
Motor supposedly has ~70k miles on it according to the previous owner. Did compression test because I replaced PCV yesterday and still had slight pressure. Cylinder 2 has 110psi while the rest are right around 160psi.
Car seems to run great though, no check engine codes, no misfires, seems to have good power.
No smoke from tailpipe either and I burned less than a quart of oil over 4,000 miles (last oil change).
How significant is 110psi? Is it likely to get progressively worse?
110psi in cylinder 2, ~160psi in the others. Options?
mudchicken
- Year and Model: 1996 850R
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
did you try a wet compression test?
2008 S60 2.5T Auto (Sold)
mudchicken
- 1884 Views
Last post by precopster
- 1235 Views
Last post by eEuroparts
