1996 850R
Motor supposedly has ~70k miles on it according to the previous owner. Did compression test because I replaced PCV yesterday and still had slight pressure. Cylinder 2 has 110psi while the rest are right around 160psi.
Car seems to run great though, no check engine codes, no misfires, seems to have good power.
No smoke from tailpipe either and I burned less than a quart of oil over 4,000 miles (last oil change).
How significant is 110psi? Is it likely to get progressively worse?
110psi in cylinder 2, ~160psi in the others. Options?
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
did you try a wet compression test?
2008 S60 2.5T Auto (Sold)
mudchicken
- Year and Model: 1996 850R
Yes, results were not significantly different from dry test
- 2161 Views
Last post by precopster
- 15 Replies
- 2918 Views
Last post by 1ezliving4ume
- 521 Views
Last post by E Showell
- 4101 Views
- 1432 Views
Last post by oragex
