Anti skid service required
Hey all.. So, the question is.. do I need to go to the dealership after replacing the clock spring to have it calibrated. If even I have vida/ dice? The prompt came up.. antiskid service required and many say that the most common problem is the clock spring assy. Thanks in advance MDK
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Look first at the yaw sensor under the right front seat, see if it has corrosion on it
Also make sure the steering wheel is perfectly centered as you drive straight down the highway. If it's slightly turned to either side, it fools the stability control to think there is a problem with the system
- Has thanked: 294 times
- Been thanked: 767 times
Is this what yaw sensor corrosion looks like? https://www.ebay.com/itm/274532841668oragex wrote: ↑23 Jan 2021, 15:19 Look first at the yaw sensor under the right front seat, see if it has corrosion on it
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
What are the codes for the abs?
Any time there is or was a prompt there are or were codes. That's how the prompt works. Use VIDA to get the codes, post up what they are.
SAS is common I agree but overall there are tons of reasons to get the antiskid message, so when you do you want to look at the set codes.
Unclear to me if the SAS requires calibration, worth it to continue pushing on that too question too.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
