Just ran my new(to me) 850 out of gas , now it won’t start!?!
NUTSinTHEwind
Year and Model: 1996 850
Post by NUTSinTHEwind »
:? So I just got an 850 with less then a 100k on it.... yesterday I ran it out of gas an barley made it home. It wouldn’t start again. I went an got a fuel filter an replaced it .... it fired right up an I took it around the block a couple of times ... all good. I then went out to run some errand an what not ... was going good for about an hour (15miles) now it’s not starting ... I can hear the pump turning on.... but havnt checked the pressure yet.... anything else I should be doing or looking into....
Ps I love this car. Any an all help/tips will be very much appreciated... thank you
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
99.9% you fried in-tank fuel pump since the car ran out of fuel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Filter may be plugged up again.
Contaminants that settle to the bottom of the tank, can be stirred up and sucked up into the fuel system when the tank is run low. Check the filter again. Then start look for other parts of the fuel system that maybe plugged up.
Active
Past
Has thanked: 1609 times
Been thanked: 4065 times
You can use a tire pressure pencil gauge to confirm the fuel pressure at the rail. Throw it out when done as it will be full of gas
misha
Post by misha »
RickHaleParker wrote: 17 Apr 2021, 16:35 Filter may be plugged up again.
It would be almost impossible because of fuel pump screen filter in the tank(first line of defense).
If something is plugged up in the system after fuel starvation situation...it would be a screen filter in the tank.
I would say that after the fuel pump ran out of fuel...it ran bone dry for a while...and few seconds are enough for that.
It was overheated internally and overheat damaged internals of the pump.
The part where it ran for a while and car was driveable was just a borrowed time for the pump.
The other scenario is plugged up screen filter on the bottom of fuel pump and if that is the case....it can also damage and overheat the fuel pump internals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
What misha said. Check the fuel pressure (what abscate said) to find out.
