Had battery disconnected now no fuel pump
Ut4life58
Year and Model: 2006 v50 t5
Post by Ut4life58 »
Hey guys. In need of some help here. Have a 2006 v50 t5. Its my first volvo and I recently did a head gasket job. Put it back together and got the immobilzer code so I cleaned all my connectors and harnesses and it fired up. Ran a little rough and smelled a lot of fuel. I believe the throttle body hadn't adjusted yet but I killed the engine. A couple days later I go to crank it and it would turn over but not fire up. Drained the battery down in the process. Not all the way but close. Put it on a 24 hour charge and now when I put key in number 2 position the fuel pump is not kicking on. That might have been happening when I drained the battery as well. Was so anxious to get it going that I didn't pay close enough attention. It did fire up for a second today but def. Not getting fuel and died seconds later. I checked fuel pump fuse and swapped out the relay. Still nothing. I don't have the code reader or anything and not a lot of money to put in shop right now. Any suggestions? Any help is greatly appreciated!!
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
If you drained the battery way down it could take days to recharge if the battery is in good condition longer if it is not. Put it back on a charger for a couple of day. Then take it to parts store and have it bench tested.
Active
Past
