test check valve
tommylg
Year and Model: 1998 s70 glt
Been thanked: 3 times
test check valve
Post by tommylg »
1998 S70 Glt.
I have had a 410 code a few times and have done resets w/a scanner.
Now it is time to figure out the issue.
Fisrt thing is to test the check valve. I belive it is a one way valve. How do I do that and is it located near the radiator?
Additionally, here is an image of my Prancing Moose sunscreen, courtesy of Dave Barton, kinda cool.
Thanks and have a great day,
Tommy
Year and Model: 2001 V70
Has thanked: 930 times
Been thanked: 1005 times
Post by volvolugnut »
Once you locate the check valve, use the handy vacuum tester and assorted hose adapters to try to hold vacuum both ways. One side should hold steady vacuum for several minutes and the other side should have no flow restriction.
tommylg
Post by tommylg »
With the air filter housing up I can almost stop the motor - what does this mean?
Thanks, go Vandy, ha.
Tommy
tommylg
Post by tommylg »
So, I found that the 90* hose is degraded.
What size is this elbow and I really need an answer to my original post, if you please.
Tommy
Has thanked: 1511 times
Been thanked: 3829 times
Need some pictures, I’m not sure what parts you are asking about
tommylg
Post by tommylg »
90* hose coming off the sas check valve replaced.
I will run a scan in the am.
The air sucking under the air filter housing - that almost kills the motor - means I have zero vacumn leaks.
Tommy
