Electric Floor Jack Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Electric Floor Jack
Post by Oka »
Hello folks, wondering if anyone has an electric floor jack. If you do, what's your take on it?
Thanks
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
No, tell us more. It has to be electrically operated hydraulic I assume, to use small motion to lift large weight....?
Oka
Post by Oka »
BlackBart wrote: 30 Jun 2021, 18:26 No, tell us more. It has to be electrically operated hydraulic I assume, to use small motion to lift large weight....?
Here's a YouTube typical video. Seems it's just for 12V battery operated; does not have a combination of AC also.
I still like it with it's only 12V. Will be very convenient for me.
https://www.youtube.com/watch?v=jq0yizqa2iw
BlackBart
Post by BlackBart »
I've never seen one of these. 5 tons is impressive. Make sure you use jack stands as well.
Oka
Post by Oka »
BlackBart wrote: 01 Jul 2021, 11:29 I've never seen one of these. 5 tons is impressive. Make sure you use jack stands as well.
Thanks about the caution!
I currently have a nice high capacity floor jack. I have NEVER EVER jacked the vehicle up, without two jack stands, no matter, even for a quick work. I’m always paranoid about fails. None of my past and present Jack’s have ever failed, but jack stands are always used.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
$120 to jack your car.
I used to use an 18v drill to drive my scissor jack, it was a lot faster.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
Scissor jacks (even Volvo) are scary. But not as scary as the 60's bumper jacks.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Rather take the time to build this DIY Car Jack / Car lift.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I think a good electric floor jack would be pretty neat. But most ones you can find have negative reviews when used for a while. I would surely like one with a Li-Ion battery. Perhaps the market will move more into this in the future
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
I have considered all the above Jacks / Lifts and others not mentioned.
Here is one with decent ratings.
https://www.costco.com/12v-portable-hyd ... 19682.html
After years of using a cheap $20 3 ton floor jack from years gone by it finally gave out. Purchased the QuickJack but returned it after not feeling safe under it. They have some impressive videos showing how safe and sturdy it is but having used one both my Son and I don't feel safe under it so returned it. Not sure if they changed some of design flows I wrote them about.
https://www.costco.com/quickjack-5%2c00 ... 66851.html
Then there was the HB Jack Stand recall. After some research settled for 2 of these Jacks and 4 Stands with the safety. Solid as a rock but we still keep the Jacks slightly under pressure in the middle unless it's in the way. Garage didn't have enough height or the van would be much higher. The Jack at the time was not the cheapest nor best quality but Costco return for defects and warranty is just so painless as UPS picked up a broken one. So easy to use and safe!
https://www.costco.com/cat-3-ton-low-pr ... 07254.html
Yikes almost doubled in price but worth the peace of mind.
https://www.amazon.com/Pro-LifT-T-6906D ... 282&sr=8-9
