Two winters ago, the door key cylinder froze. At the moment, my option was heating up the inside of the cylinder to be able to turn the key. I used an old smaller key, from a non exiting car, heat it up and plunged it inside the cylinder. The heat melted the ice. I was able to unlock the door with its (Volvo) key. I later started using the key fob. Much later, I tried to use the key, the cylinder will not turn; till now.
I just removed the key system and the cylinder, which seems to have some crud on the outside. Got them all cleaned up.
If I pull out the guts of the cylinder, will I able to put them back, or is that only for the locksmiths?
Thanks
Door Key Cylinder
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
Door Key Cylinder
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- 2351 Views
- 1906 Views
Last post by precopster
