91 240 wagon - exterior light problems
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
As you can see from my other posts, this is a very, very, very challenging period for me and my junky fleet of RWD Volvos :( . My patience is definitely being put to the test. Before posting my question, I'll mention in passing how just two days ago, yet another car, my daily driver, a 90 740 wagon, blew the head gasket at 290K. That repair seems like a breeze compared to the other issues, including this one.
Weird issues with the lights in my 240 wagon. Key in "on" position, the three brake lights and front left running light all turn on and stay on. Turn the ignition on, no change. Turn the car off, all lights turn off. I swapped out the bulb failure relay just for kicks, and that did nothing.
Thanks.
Wagons:
93 940
91 240
90 740
86 740
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Sounds to me like a low voltage battery or bad power connections. The attempt to start requires more current than the battery can provide and everything goes dark. If the the car starts and runs ok, then check power connections to the ignition switch. Position 2 and 3 may have different connections to the lights.
Keep trying, these rear drive Volvos are worth saving.
e777
Post by e777 »
volvolugnut wrote: 16 Jul 2021, 15:04 Sounds to me like a low voltage battery or bad power connections. The attempt to start requires more current than the battery can provide and everything goes dark. If the the car starts and runs ok, then check power connections to the ignition switch. Position 2 and 3 may have different connections to the lights.
Excellent suggestion. I will check the ignition switch. thanks.
Wagons:
93 940
91 240
90 740
86 740
