Pulled fuse for instrument panel
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Holdtron88
Year and Model: 2002 V70
Volvo Repair Database Pulled fuse for instrument panel
Post by Holdtron88 »
I’ve recent acquired a very clean 2002 V70. I was checking the fuses on the panel inside the driver side door. I pulled the wrong one and it was the fuse for the instrument panel. Now I have a srs airbag service urgent and alarm system service urgent code showing up on the dim. Can I reset/ clear this with out a VIDA/DICE. I’ve bought one. Is currently in shipping, just wondering if there is a reset procedure.
Thank You
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
I didn't know pulling a fuse could set the SRS, that doesn't sound right.
Holdtron88
There were no messages on the dim before I pulled the fuse, now 2 messages. Idk I will wait till my new scanner comes in, No airbag light just the message on the DIM.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 17 times
Been thanked: 33 times
Post by ignatz »
I've had 4 different 01 to 05 Volvo's. Everyone threw an Alarm service message at some point. All took that module around the front fender. All the cars had different ways or times that would tell me something was wrong with the car. Our last 05 S60 2.5T awd threw the alarm code on the way home after buying it. We pulled over somewhere, locked the car, and the message appeared after unlocking it.
Not sure about your SRS light.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Has thanked: 1511 times
Been thanked: 3827 times
If you deposed the SRS system with the rest of the car powered up, you can setban SRS code which will require VIDA to reset
General rule, any SRS work, disconnect battery
Holdtron88
Thank you very much for the help, my VIDA will be here in a few days.
