XC90 antifreeze loss
croderique
Year and Model: 2006 XC90
Post by croderique »
We purchase a used XC90 in May and it continues to require about a half quart of antifreeze per week. We took it to a Volvo mechanic who checked it over, did a coolant compression test and couldn’t find any leaks.
Any ideas from the forum would be appreciated.
Thanks
Chuck
Volvo 2006 XC90
Phoenix, AZ, USA
croderique
It is a 2006 with 124k miles.
Volvo 2006 XC90
Phoenix, AZ, USA
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
If no external leak on the driveway then...
- Check the heater core, which is notorious for leaking after 100K.
- I wrote a DIY here...
DIY: 2005 XC90 Heater Core Replacement
viewtopic.php?t=82726
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
Sometimes they leak but don't drip at the base of the thermostat housing, the top hose, look for crust there.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 125 times
Post by ggleavitt »
2006 had 3 motors in North America alone, there is no way to guess this in advance. It's information that's easy enough to append permanently into your signature (add a 2.5T, T6, or V8) then no one needs to ask. FWD distinction (if it's not AWD) helps as well. Can do as signature and/or profile, both will be noted on all of your posts.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
Capndirk
Year and Model: 2009 XC90
Has thanked: 7 times
Been thanked: 11 times
Post by Capndirk »
You don't mention the engine, but I had a phantom leak on my 3.2. It needed half a liter every month or more. I finally saw a build-up of fuzz at the lower hose connection, and a greasy build up on the body wayyyyy below it. The coolant bottles are notorious for leaking there (and elsewhere). It looks like the clamp is at fault, but it is actually the bottle.
