A few days ago I zeroed my odometer (the car was stopped) and my odometer stopped working. I thought the gear was broken but the next day, after driving to my office and leaving the car in the parking lot (exposed to the sun) it started to work again. The same happened already three times. In the morning it does not work but when I drive home it does.
I was told it could be an ABS module. I upgraded mine a few years back.
Any help greatly appreciated.
odometer is working intermittently
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Odometer on 850 have nothing to do with abs...as long as speedometer works.
If speedo is working intermittently along with odometer...that would be the sign of bad abs module or abs sensors.
Do you have abs/tracs light ON when engine is running?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Then ...it's gears in odometer...which will fail completely...pretty soon.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
Why would it work when the car is hot? Those plastic gears do not expand to engage at the higher temperature and contract at lower one. It looks more like an electrical connection.
I agree that it would indicate gears failure especially when I noticed it after zeroing the trip counter
januwan
- misha
Don't know why but mine did that too...and pretty soon they failed completely at 181k km.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
- Been thanked: 979 times
A plastics without a coefficient of thermal expansion ... wow! You got a name for that wonder plastic?januwan wrote: 17 Jul 2021, 15:16 Those plastic gears do not expand to engage at the higher temperature and contract at lower one.
Active
Past
Past
ShrinkRap....a new genre of Psychologist MusiciansRickHaleParker wrote: 18 Jul 2021, 04:12A plastics without a coefficient of thermal expansion ... wow! You got a name for that wonder plastic?januwan wrote: 17 Jul 2021, 15:16 Those plastic gears do not expand to engage at the higher temperature and contract at lower one.
januwan
The gears are made out of ABS (most likely) which will expand 10 µm per 1 °C. This would result in 200-300µm expansion which cannot be the reason my odometer does not work properly. That is what I was trying to say. Of course, plastics expand but in this case, it is negligible.
It is better to say nothing if you don't have anything constructive to add.
januwan
- RickHaleParker
If it is in good condition. Right on the edge is another matter. Clearly, it is not in good condition.
What drives the odometer? Pictures are worth a 1000 words.
Active
Past
Past
- 2015 Views
Last post by Ozark Lee
- 1953 Views
Last post by marcsanders
- 479 Views
Last post by Clemens
- 4169 Views
- 520 Views
Last post by 93Regina
