Dropping the Fuel Tank What Hoses/Gaskets To Change?
98V70T5
Year and Model: V70 T5 1998
Post by 98V70T5 »
Hello,
I am dropping the gas tank on a 98 V70 T5, to change a fuel line. What fuel tank gaskets, and hoses should be pre-emptively changed while I'm back there?
I have heard of some hose that can leak when you fill up, two evap hoses, fuel neck to tank gasket, should be changed. Any others or tips I should consider?
Thanks!
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I'm getting ready to do this as well. I just bought every one that was listed through FCP or IPD. I think there were only three but I do know that in my case one was no longer available. I figure if I'm doing it, then might as well do all of them including the filler neck doughnut.
1999 V70 GLT
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Replace as many of those lines as you can while you're in there. I think @Abscate has some pictures of one of the tanks recently that he dropped.
Check your fuel filler neck clamp about half way down it (can't remember if yours has this) the clamp rusts away over time and gives you large PCV leaks during acceleration/deceleration.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Here's a whole bunch of info from guys who have done this https://www.matthewsvolvosite.com/?s=drop+tank
Also -> Amazon link
