Manifold bolt broke
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Manifold bolt broke
Post by loveMy850 »
Did the pvc and a bolt broke, mine is a 7m. For a helicoil do I want to get a 7M. Healy coil? Any other suggestions before I even go that way would be greatly appreciated. Thank you...
Has thanked: 1851 times
Been thanked: 1712 times
Did it break off flush with the surface of the head? Did it break when undoing or when tightening?
loveMy850
Post by loveMy850 »
It broke off when tighting. I haven't taken it out to look, I'm hoping the end will be sticking out of the intake and maybe I could take some plyers and get it the rest of the way out, but if it isn't then what?
loveMy850
Post by loveMy850 »
Hi Neil, It broke off when tighting. I haven't taken it out to look, I'm hoping the end will be sticking out of the intake and maybe I could take some plyers and get it the rest of the way out, but if it isn't then what?
loveMy850
Post by loveMy850 »
I may mean the block sticking out don't I? I'm nervous over the Healy coil thing.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
You should be fine. At least it's on the intake side, not the exhaust. Lots of room to work and since the intake really doesn't get hot, I doubt there would be any warping if you ended up without a bolt. If it's sticking out, then vice grips might do it. If it's flush or below the surface, then a reverse drill bit should get out. If not that, then an extractor. I doubt that you'll need to go the Heli-core route. You could probably re-tap the hole and use some locktight before needing the Heli-core. But I don't think it will be any kind of an issue.
1999 V70 GLT
Hopefully it broke above the surface! As has been suggested a reverse drill might tease it out and at least the inlet is more accessible as has been stated.
Good luck!
loveMy850
Post by loveMy850 »
Thank you for the replay.
Life's Lessons. ❤️👍Thanks Matt and all the team.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Irwin bolt extractors are amazing for grabbing studs which are slightly exposed. They also work on bolt heads which are badly rusted or rounded. Check out the common sizes in Irwin 394001 and the uncommon sizes in Irwin 394002.
FireFox31
loveMy850
Post by loveMy850 »
Thanks for that, I'm at the auto parts store now I'll look for that, it's suppose to be 108 on Sunday working on my Volvo.. ugh. Hopes it's sticking out. OMG
