850 AC Compressor Topic is solved
manovlov
Has thanked: 620 times
Been thanked: 143 times
850 AC Compressor
Post by manovlov »
Hy Buddies,
Is it necessary to move out the fan radiator to extract the AC compressor from the car ?
I will replace the alternator by the way (to begin with that), won't i have enough space to pull out the AC device ?
Manov
Has thanked: 1841 times
Been thanked: 1709 times
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
Removing fan is pretty easy, and you will have much more space for work.
If my English is bad, please correct me :oops:
manovlov
Post by manovlov »
scot850 wrote: 08 Aug 2021, 11:43 Does this help?
http://www.volvohowto.com/volvo-850-s70 ... lternator/
Hey, Yes just what i was looking for !
Merci beaucoup !
Manov
You are welcome!
manovlov
Post by manovlov »
Azik09 wrote: 08 Aug 2021, 12:42 Removing fan is pretty easy, and you will have much more space for work.
Azik09, i found a FCP video that explains how to move the fan, but i won't have time this week to do so. Do you think it's possible to extract the compressor without doing so ?
FCP Video :
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Just be careful not to damage your radiator
manovlov
Post by manovlov »
Ok. Thanks a lot Zi
Manov
manovlov
Post by manovlov »
Because i haven't got enough time, i won't replace the compressor. I thought to replace the alternator by a new i bought for my 1998 V70 Diesel, but the parts are differents. Same sizes but fixing screws holes differents.
I will reinstall the one i have, clean it before of course, and i will see later. For the compressor AC i will take the end of the year to put clerly the scheme on a piece of paper and list parts and seals i need. For spring 2022.
I am infinitely grateful to you all for your kindness and your wise advice.
Manov
Azik09
Post by Azik09 »
1998 diesel is an Audi/VW engine... All mounting points of all agregates are different from your B5254. The only way is to assembly internal parts of D5244's alternator with the B5254's alternator housing. Isn't it easier to buy properly spares (brushes, contact rings, bearings etc) and fix your alternator?
I couild give you all needed partnumbers tomorrow. And some instructions with photos too, if needed. Right now I have 850 for engine swap in my workshop.
