Fuel pressure
RTAuto8376
- Year and Model: 2005 S60 2.5T
Fuel pressure
Working on 2005 S60 2.5T. car runs fine for a few miles then starts to miss and buck and sometimes stalls. Scan tool showed loss of fuel pressure. Replaced fuel pump fuel pump control model ,fuel filter, and fuel rail pressure sensor. Have cleaned all grounds I could find and replaced body to engine ground. Removed ECM and cleaned contacts all to no avail. ECM throwing two codes. Faulty fuel pressure signal and fuel pressure signal low. Any suggestions?
RTAuto8376
87K miles. I have done that also. Same results
TomMills
- Year and Model: 2006 v70 awd
I have a similar issue. 2006, V70 AWD, 235 000km. Replaced same parts as you. Both my OBD reader and fuel pressure gauges read 294-310kPa (normal), even while driving. The car drives perfectly until it doesn't. At a point while trying to accelerate, it misses, stumbles, and, if I'm not quick to back off the accelerator, will shut down. I can slowly get back on the throttle and it struggles on. If I shut it off and let it cool down, it will fire right up and behave until it doesn't. The most frequent DTC is 089 (Fuel Pressure Sensor). It appears to me that the problem is heat related. This suggests either an ECU or CEM cooling issue. They are both too expensive to just guess at replacing (or having rebuilt/reflashed). Thoughts?
RTAuto, do you think your issue is heat related?
