Preparing for Road Trip
boreimann
Year and Model: 2007 S40 T5
Post by boreimann »
I have a 2007 S40 T5 with 110k miles. I'm moving in a few weeks and will be driving from Chicago to Boston so I'm making sure everything is tip top before the journey. The transmission fluid has never been changed but there are no symptoms of a faulty transmission at all, it shifts smooth. Any recommendations on changing it or not?
Also any other recommendations? So far I have changed the timing belt/water pump, replaced front suspension, changed all rotors and pads, replaced and balanced tires.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Brake fluid flush? Spare bulbs and fuses? Maybe a spare coil and plugs? Spare tire checked and good?
Has thanked: 1610 times
Been thanked: 4071 times
No reason to flush the AT. It’s pretty flat between ORD and BOS so the AT won’t be stressed. You should be thinking about doing the drain and fill routine 2-3x to refresh the AT fluid about now though.
I’m in ALB if you are passing by or need help.
