Bare with me guys new to this.
Whilst driving my 2006 v70 2.4 d5 there was a sudden loud popping air release type noise. Stopped immediately thinking a tyre had blown, which it wasn't. When setting back off it immediately stalled. Tried again slowly, the car won't go past 10mph due to it constantly jerking jumping violently. Car ticks over fine, but when revved it fluctuates up and down. Hard revs produce grey smoke from exhaust and smoke comes from where the swirl actuator link connects to the head.
Any advice will be greatly appreciated.
Regards Craig.
V70 violently jerks
Whilst driving my 2006 d5 there was a sudden loud popping air release type noise. Stopped immediately thinking a tyre had blown, which it wasn't. When setting back off it immediately stalled. Tried again slowly, the car won't go past 10mph due to it constantly jerking jumping violently. Car ticks over fine, but when revved it fluctuates up and down. Hard revs produce grey smoke from exhaust and smoke comes from where the swirl actuator link connects to the head.
Regards Craig.
Regards Craig.
We don’t get the diesels here , Craig but if it’s a turbo car I would guess an induction hose has popped off
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
Do you have a check engine light? ive blown a turbo hose , a piston ring and head gasket. none made the car jerk. sounds like a missfire, got to check what codes your getting.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Yeah, that sounds a bit like overboost and a hose blowing off. Also check the intercooler case and fittings. (Does a diesel have an intercooler?)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
jerking might be transmission shifting being affected by the boost leak, loud hissing on mine was the boost pipe coupler hose clamp coming loose. That triggered limp mode. soon followed by turbo shaft breaking. Not necessarily in that order.
- darylrobert
Manual transmission wont jerk just no power and you would see black smoke, thats why i thought missfire which i think is white smoke?. Sorry dont know much about auto's
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
That happened recenetly to a diesel Volvo fellow: bolts of one of the fuel injector stripped the threads inside the head. One bolt first, the other remaining bolt didn't leave much longer. The injector flew away, causing wreckage along the way.
- 748 Views
Last post by Brandonmt423
- 2326 Views
Last post by oragex
- 1863 Views
Last post by highmiles
- 779 Views
Last post by E Showell
- 4514 Views
Last post by tfo
