Anyway, here is what I am now dealing with (a real gem of an electrical problem).
- The headlight switch has three positions, off - running lights - head/tail lights
- When I turn the switch to the middle position, the overdrive arrow illuminates as does the defroster switch (!!)
- When I turn the switch to the third position, the overdrive light and defroster switch turn off
- This may or may not be connected to the ongoing issue of my brake lights remaining illuminated after my foot is off the brake and until the ignition is turned off (Turn the car on again, no brake lights illuminated until you tap the pedal again, and the same loop continues ad infinitum).
- The bulb failure relay is good (it works properly in my other 240)
- The brake light switch is new and functions properly (tested it in my other 240)
- This car is all stock. There is no funky custom wiring, spliced wires, etc.
II realize this could be ignition-switch related, but I hope to rule out the easier fixes first.
Thanks in advance for any advice you might be able to offer!
