I have noticed that i am burning a lot more fuel lately.... doing 17-19L/100km, where i have been doing 10-13L/100kms for years now. What are some things that could cause such an increase? I thought possibly a bad wheel sensor as I replaced a ball joint recently or something with the computer, but I am at about 1/2 tank of full tank with only about 200kms done....so must be right.
Just a note that i just replaced the throttle body, have an engine light with p2401 and p2419 codes and recently changed front passenger wheel bearing.
Any suggestions on things to check??
Excessive fuel consumption all of a sudden??
If those codes reflect engine management problems you may be running in the static fuel map rather than than close loop. This will run rich with high fuel consumption to protect the engine from damage.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Figured I would add to this thread. Working though fixing some issues on a new to me 05 XC90 2.5T. One left to do is a check engine light with P2401 and P2419 codes.
Any suggestions on where to start? For $50 worth changing EVAP Canister Purge Valve? I've yet to check the wiring first as both codes are circuit low.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
Just a followup on P2401 and P2419 codes, definitely check wiring. Made a seperate thread in XC90 area for my fix.
viewtopic.php?t=101395
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 1885 Views
Last post by chrism
- 540 Views
Last post by erikv11
- 2286 Views
Last post by cn90
- 3401 Views
- 57 Replies
- 27940 Views
Last post by shadetree_v70
