Hi, Gang,
While proceeding with fuel pressure testing, I removed the cap from the Schrader valve at the end of the fuel rail.
Fuel flowed out quite readily. Does anyone know part number? Is this the same size as the others in the fuel lines?
Thank you.
Bill
Fuel Rail Schrader Valve Q&A Period
- Been thanked: 504 times
Are you asking about the cap or the "valve core".
I think the valve core is the same as a tire valve core (please verify).
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Please let us know what pressure you see when you test. My 2006 S60 2.5T starts at 55 PSI but drops to 43 after about 30 seconds, measured on Torque and with an autopart store loaner fuel pressure gauge. Wondering what others see.
there is both a pressure spec and a drop spec after 30 minutes - I think your pressure is ok, but you are failing the drop test.EngineeringBloke wrote: 03 Nov 2021, 09:41 Please let us know what pressure you see when you test. My 2006 S60 2.5T starts at 55 PSI but drops to 43 after about 30 seconds, measured on Torque and with an autopart store loaner fuel pressure gauge. Wondering what others see.
viewtopic.php?f=9&t=96224&p=565820&hili ... ec#p565820
- 2266 Views
Last post by Ozark Lee
- 346 Views
Last post by misha
- 5211 Views
Last post by Botbasher
- 3341 Views
Last post by 800artfreed
- 2628 Views
Last post by Chuck W
