Volvo 740 Wagon WHISTLING! Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Michaejalopy
Post by Michaejalopy »
My 1990 740 Volvo Wagon whistles..... it increases in pitch as I speed up.... Maybe it's from the cold weather? I live in Canada and it's been about minus 20 Celcius lately..... any ideas would be appreciated! Thanks. --freezing in Canada!
Joe
Post by Joe »
your brakes could be getting bad. after brakes ware down they get to a stage in the brakes whare it make a wistling noise it tells you to change it. so check your brakes
Volvord
Post by Volvord »
You don't mention what conditions the whistle occurs, but the 700 series is famous for the windshield molding coming loose which creates a whistle as vehicle speed increases. You can fasten it down by replacing the broken clips, (which is a real pain) or just use some small dabs of silicon sealer (adhesive) and "glue" the trim back on.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
