Antlia rims for 1989 Volvo 240
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
sergitin32
Year and Model: 1989 240 DL , 1995 9
Been thanked: 3 times
Post by sergitin32 »
Hi there, I found this ad in Kijiji with a couple of rims that after searching online from the picture it looks like Antlia rims from a "2000 C70 Volvo" said the seller. (front-wheel drive?) They are not his wheels so not a lot of info from his friend owner.
After doing some research I found several conflicting info. Some people claim they fit Volvo 240s but some more official websites with wheel specs etc claim otherwise:
https://volvo-wheels.com/product/volvo- ... m-9192518/
in this website the specs say:
Bolt Pattern: 5 x 108mm
Diameter & Width: 15″ x 6.5″
Offset: 43mm
I want to put these with the winter rubber he also has in the ad in my rear end.
Here is the question, I do have a 25mm wheel spacer from IPD in the back with my Virgos and I had to roll my fenders a little bit to avoid rubbing.
My reasoning is that if the Virgo is 20mm positive offset and the spacers are 25 mm then they should be in general like a 45 mm wheel. so these ones with 43 should be OK in there as long as the tires have a very similar profile, but then these rims are 1/2 inch wider than the Virgo...
In one question, does anyone knows for sure if these would fit, with or without the spacers in the back.
Thank you.
1989 Volvo 240DL , 1995 Volvo 960 Sedan , 1995 VW Rialta , 1987 VW Cabriolet
850 LPT
Year and Model: 96' 850
Has thanked: 332 times
Been thanked: 242 times
Post by 850 LPT »
They will most certainly fit, but you would need to install the 25mm spacers on both axles.
I have a set of 16 x 6.5 Helium wheels with 205/55/16 on our 240 (Frieda) and it works just fine.
These were originally on 2000 S70 only.
I hope that helps.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
