Hi there,
New to this forum. I have a 2008 XC90 3.2 FWD. It appears that info from Cilton and other manuals tells me all different spec.
I appreciate it if anyone here kindly provides me with details on torque spec.
- Torque on 2 carrier bolts that hold the passenger side axle shaft carrier bearing support bracket. (This is not the bolts that fasten carrier bearing anchorage against the engine.)
- Torque on 2 bolts (upper and lower bolts) that fasten the wheel spindle against strut. (2 Parts Torquing: Ft-lbs & Angle Torque)
- Torque on the Axle bolt.
Thank you
Sean
08 XC90 3.2 Passenger Side Axle Shaft Installation
Capndirk
- Year and Model: 2009 XC90
- Has thanked: 13 times
- Been thanked: 14 times
Here's the page from VIDA that lists the torques for the axle group, I didn't find the torque for the bearing cap 2 screws that contain the bearing. If the parts are clean and well mated, the torque by bolt size will have to do. I put a drop of blue loctite on mine. 20k miles and holding.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Carrier bolt is M8x35, can use the table on page 1. The others are explicitly called out in the reference.
- 5196 Views
Last post by SuperHerman
- 1098 Views
Last post by arvik
- 1392 Views
Last post by hapyendin
- 2019 Views
Last post by chrism
- 3654 Views
Last post by precopster
