Here is a photo of my block. I have cleaned it with a rag and solvent, but it does not make it any cleaner than this. Is the surface that will contact the new head gasket clean enough, or does more work need to be done? If so, how would I clean it?
Click here to see it full screen
Is my block clean enough.
- Has thanked: 1511 times
- Been thanked: 3827 times
Use this product, let soak overnight
Mopar upper cylinder cleaner
Pictures in this thread in the cool kids P80 forum here...
viewtopic.php?t=96254&hilit=Elizabeth&start=80
- 786C639C-9148-4DF0-BD9B-55FEBCEA1BF1.png (4.4 MiB) Viewed 804 times
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
The product in the photo says combustion chamber cleaner, and it looks like you are only cleaning the cylinders. Are you saying it will work for the mating surface where the block contacts the new head gasket? That part is what I am concerned about being clean or not.
2002 v70 X/C 288k miles
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 609 times
Is it old gasket imprinted on the metal?
That was mine a few minutes before the head went in:
Plastic blades, Permatex 80645 Low VOC Gasket Remover and acetone as a final step.
- Has thanked: 294 times
- Been thanked: 767 times
I would clean it more, until no bumps anywhere and remove as much gasket residue as possible. Just not worth getting it wrong. Takes a few hours with razor blades (be careful - for you and the head surface!) or at least with plastic blades. Last one I did the Permatex product was worthless but the 80645 is a new one I'd definitely try it.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
The block face looks fine except around the lug between cylinder 1/2 intake side. Clean that yo shiny metal a bit more.
The carbon needs to come off this pistons though. Keep paper towel bits out of the dump, I managed to clog my oil pickup on my last job
See before after piston pics
- 52D25F37-11A8-415A-B66B-5E30F454CF45.png (8.3 MiB) Viewed 734 times
- 3DB29C19-3194-408B-96D7-704A5D020BD3.png (10 MiB) Viewed 734 times
Was #3 steam cleaned due to a leaky head gasket?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 1264 Views
- 9279 Views
Last post by MadeInJapan
