exhaust issues? Topic is solved
SirBrickWagon
Year and Model: 1997 Volvo 850
Has thanked: 7 times
Been thanked: 11 times
exhaust issues?
Post by SirBrickWagon »
Recently took my car to Mr. V Plus to get my exhaust headers replaced as the last one's flex joint was completely blown off. went to start my car again today and it sounds like a tractor. No clue what the issue could be. oil?
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
SirBrickWagon
if it matters, this is the manifold i bought. could it be that the small bolt on the side of the pipe came loose and is only making 1 cylinder loud?
https://www.rockauto.com/en/moreinfo.ph ... SP1Q%3D%3D
Has thanked: 1836 times
Been thanked: 1709 times
Chances are a weld has broken or it is not sealing properly. As you supplied it, the repair shop ma not look to favorably on doing anything if it is not an install labor issue.
Has thanked: 1497 times
Been thanked: 3810 times
Definitely check the SAS bung to see if it’s loose. A tractor sound describes it perfectly, when it’s loose.
SirBrickWagon
yet another ridiculous fix. low and behold, it was the bolt where an SAS would be (i suppose it would be deleted, there's no valve), it was loose when i was gifted it and the force from the car starting was enough to force it out after 4-5 short drives. glad it was a simple fix of finding it sitting in my engine bay and snugging it back up.
Well done abscate with that ID!
