Usually you can’t swap radiators on the98, 99 chassis change because the ATF hose fittings change
With an m56, though, I believe that the only change is from the coolant overflow hose connecting at thermostat (98) vs the radiator (99)
Looks like a 98 radiator with a 98 thermostat housing would go into a 99 m56 car?
Any thoughts?
P80 radiators -98 , 99-00 m56 cars
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Just stared at one of each of mine, I concur.abscate wrote: 19 Mar 2022, 04:42 Usually you can’t swap radiators on the98, 99 chassis change because the ATF hose fittings change
Any thoughts?
- 1022 Views
Last post by bmdubya1198
- 13 Replies
- 2486 Views
- 1478 Views
Last post by snowcamper
- 377 Views
- 18 Replies
- 2475 Views
