Is it car work weather at your place today?
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Could you work on your vehicle outside today If needed? Is the weather too hot/cold/wet/windy/other disagreeable? Do you have to work on it anyway because you need to drive? Curious people with little to do want to know.
Currently, it is perfect car work weather here. Not hot, cold, wet, or windy.
BlackBart
Been thanked: 884 times
Post by BlackBart »
55 here boss, at 12:30. But I’m going for a bike ride instead. I think I’ll swap out the snow tires and give her a wash later.
Has thanked: 1505 times
Been thanked: 3818 times
For Volvo work I’m up for, in the 12054…….
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
It is a bit cold here, right at 32°F/0°C. I got some more glue so fired up the space heater in the garage to keep pulling/massaging the dent out of the door on the 2002. Slow process but it is looking better.
08 C702.5T (sold)
The non-Swedes:
It is 7:15 PM and Accuweather says is is 106 F. The high today was forecast to be 107 F. The low tonight is forecast to be 74 F.
My outdoor work day is getting very short - about 7:45 to 10:30 AM. By then it is near 90.
This weather will continue without much change for 2-3 weeks according to Accuweather.
With my life split between 12054 Albany and 11777 port Jefferson if I can get out of the sun both locations are good temperature wise.
I put EvitatheS70 on ramps in tree shade to inspect the evap lines yesterday, NPF. Running a bit high on fuel trims, 12-14%
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Too hot here. Should be in a new house with garage in September. After that I can work on the car at night when it is too hot or with a space heater when it is too cold.
Krons
Post by Krons »
Too hot here as well, 90°F+.
Did an oil change on the kids Ford Focus this weekend, very easy job on that car. Decided to do a partial Steering Fluid flush on the 2008 S60, didn't quite have enough ATF to do the whole job plus the heat didn't help motivation.
08 C702.5T (sold)
The non-Swedes:
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Dunno the temp but it is too darn hot! Its mornings or evenings if I can muster up strength doing anything at all.
BMW 540i 2002
S70 Base 2000
Beaten off the driveway by 1100 hours yesterday. Very hot for latitude 43 , upstate NY
We are flirting with 100F, very rare here.
