Broken direct drive belt
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Hansantl
Year and Model: 2002 70 xc
Post by Hansantl »
Can I drive two miles with out a direct drive belt? Mine has broken and I just want to get car home to do repairs
Has thanked: 1509 times
Been thanked: 3827 times
On a 2001-2007 model, yes
No power steering , wheel will be very heavy parking and low speeds
No alternator , so battery light will be on
No air conditionig
Year and Model: 2004 V70 2.5T
Been thanked: 476 times
Post by cn90 »
But you will save a few drops of gasoline bc the PS Pump and alternator are not driven.
All joking aside, yes you can drive home.
But once the drive belt breaks, it raises a much bigger issue: how old is your timing belt?
If the TB compartment has not been addressed at 130K-140K, time to do the TB, pulleys x2 and WP.
Info in forum.
PS: How many miles on the odometer?
Year and Model: 2001 V70
Has thanked: 930 times
Been thanked: 1005 times
Post by volvolugnut »
Remove the broken belt to avoid wrapping up in the timing belt and causing real grief.
jonesg
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
drove mine more than 20 miles, headlights off.
When I got home i restarted it, plenty of battery left.
So, depends on your battery condition.
A good battery will give you an hour or two of reserve. It will start and idle fine as the battery sags, but running under load will degrade first
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 609 times
Post by vtl »
You can drive, but first make sure no kevlar threads got under the timing belt. When my new Conti serpentine belt snapped partially, it caused t-belt to jump one tooth off on the exhaust side. The rest of pulleys were clogged with kevlar as well: crankshaft, PS pump, alternator, A/C compressor - just everything.
