V70 no start
Dkehrley
Year and Model: 1999 v70 xc
V70 no start
Post by Dkehrley »
'99 v70 xc. No rpm during crank. Code p 0343. Just replaced head gasket after freshening head as originally she just stalled. Compression is 50 lbs less unless I remove the main vacume line then it does make an attempt, It seems that the motor is not receiving air but all connections are secure. I'm at a loss, how do I test the throttle (fly by wire)?
SonicAdventure
Year and Model: 1996 850 wagon
Has thanked: 59 times
Been thanked: 12 times
Post by SonicAdventure »
Whenever I hear of P80 non-start, regardless of the error code, I think "check fuel pump relay". Always.
Has thanked: 1857 times
Been thanked: 1718 times
As Sonic says check the obvious first and the relay is that. You should hear the pump whine slightly when you first turn the ignition to II.
Setting the timing is a challenge on these engines with VVT. Are you sure the timing is 100% correct and not a turn of the crank out?
What is the main vacuum line? Line to where?
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Rpm needle is not suppose to move when engine is cranking....so i'm not sure what you meant when you said " no rpm during crank".
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Dkehrley wrote: 03 May 2022, 11:17 '99 v70 xc. No rpm during crank. Code p 0343. Just replaced head gasket after freshening head as originally she just stalled. Compression is 50 lbs less unless I remove the main vacume line then it does make an attempt, It seems that the motor is not receiving air but all connections are secure. I'm at a loss, how do I test the throttle (fly by wire)?
https://volvoforums.com/forum/volvo-s70 ... 343-16333/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Dkehrley
Post by Dkehrley »
Sorry gang I had to walk away as the obd2 connection stopped activating my scanner. That's first thing to diagnose tomorrow
The timing mark's are dead on I removed the vvt hub doing the timing (quite a task for my old school brain but thanks to this forum I think I got it right, new locking tool and all)
Compression on all cylinders
Goes up 40lbs if I allow a vacume leak on the intake manifold by pulling the vacume hose to the break booster.
I have fuel pressure on the rail (50lbs) and can hear the pump cycle. Volume seems to be fine while cranking.
New cam and crank sensors
My no rpms symptom comes from the 'live data' tab on the obd2 scanner during cranking
I'm back on it again tomorrow. It's become a mater of pride and this will not get me
P0343 is a bad signal from the crank position sensor if I read the code correctly.
Dkehrley
Post by Dkehrley »
Yes sorry the last piece of info is the generated code of p0343
I also didn't thank all who have answered this thread I guess I'm just frustrated at her at the moment
