1998 V70 AWD starting problem
Jimbo
Post by Jimbo »
This problem has happened twice now in the last month. Having starting and driven for a while and then stopped the car refuses to start unless you depress the throttle peddle slightly, and then just dies if you lift off the throttle. Turns over fine but does not catch even slightly if the throttle is closed. This problem then dissapears and start and drives fine for weeks.
Any comments welcome.
eikeeg
Year and Model:
Post by eikeeg »
I have a V70 and am experiencing similar problems - started a bit of a saga. Replaced fuel pump relay, thermostat?. cleaned earths, still a problem. Did you get yours sorted?
eikeeg
Year and Model:
Post by eikeeg »
Volvo just fitted antennae ring ( plastic surround of the ignition switch ) it contains a link to the key and the immobiliser. Known to be a problem apparently. ( cheap
