Main Fuse Box - Mass of wires? Topic is solved
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Good evening,
I found this mass of wires in the main fuse box, they appear to have been cut and spliced at some point with an adhesive heatshrink. Can anyone think of any auxiliary electrics that would have been used here, or have any suggestions as to what was removed?
Some are looped, some have three wires spliced into two, so I believe that there was something retrospectively wired into here and then removed.
Thanks,
Has thanked: 1505 times
Been thanked: 3818 times
The most common wiring mods are
Stereo amplifier wiring
Remote start
Alarm wiring
Cookeh
Post by Cookeh »
Many thanks. I haven't seen any evidence of alarms - the standard Guard II is still present and working. It's a similar story for stereos, running all original speakers and there are no mounting holes for any amps or additional wiring.
I believe that whatever it was was a Volvo item as the heat shrink matches perfectly with that provided in the ABS repair harness, and the gauge and colour of the spliced in wires are a perfect match. I don't know of that helps narrow things down.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The connectors for front wheel speed sensors had resistance on some 850s and the fix was to solder and heat shrink. That is the repair shown. If you go find the wires on right and left headed to the wheel area you'll find the brown and black sets there.
Cookeh
Post by Cookeh »
That actually makes perfect sense and explains the match on wires and heatshrink with the ABS harness repair kit. Thank you!
