Hello, I have a 1996 850 Turbo Sedan. I just found a 1997 Volvo GLT Sedan I can buy cheap for a donor car. I THINK it is the same car, but just want to verify. I am buying it for the front bumper cover, the dash and dash pad. Can someone please confirm?
What other parts should I pull off of it? I'm not keeping the donor car around for long after I get my parts off of it. I'm told it runs but has a transmission issue.
If someone wants the rest of the car and you live near MD, let me know.
-Matt
Donor car compatability Topic is solved
- Has thanked: 292 times
- Been thanked: 765 times
Engine internals and turbo - slightly different. Transmission - different.
Everything else - the same. All sensors, mechanical parts, body parts, interior etc. are the same.
If it were me I'd gab a ton of stuff. Brake calipers, the standard engine sensors (MAF, TPS, ECT, CPS) as these are known to go bad, fuel pump, fuel pump relay, maybe the radio. Whatever else caught my eye.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
What's different on the trans?erikv11 wrote: ↑14 Jan 2021, 17:05 Engine internals and turbo - slightly different. Transmission - different.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
I'm curious too.
If it's manual...there are some differences M56,M58,M59.
If it's auto....they should be all the same...AW50-42LE.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Chuck W
Yeah, that's my thinking, as well. I'm refreshing the auto I took out of my '97 T5 (which is the same as that '96 Turbo) planning on replacing the tired auto trans in the wife's '97 GLT. Pretty sure they're both the same AW50-42LE trans.
I know the manuals can be different, but even at that, a '96 and '97 FWD manual (M56) would be the same.
My recollection is that final drive ratios are different between GLT and T5 ("turbo") slush boxes, that's why I wrote that. But Maybe I am conflating a GLT/T5 difference that doesn't exist with the final drive ratio difference between the NA and turbo versions.
Backpedaling!
Backpedaling!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1505 times
- Been thanked: 3818 times
Final drive M56 4.0
Final drive NA AT 2.74
Final drive turbo AT 2.54
I thought Rs were different, too? Tandem bike backpedaling.....
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
I think the Rs in the early years are the same as far as the tranny goes. Might have changed later with the AWD Rs.
I think the early Rs just got the rims, front lip, nice interior and a different tune.
This is for AT Rs only. MT Rs got M4.4, the special tranny and 16T.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
