850 Front axle alignment issue Topic is solved
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Re: 850 Front axle alignment issue
Post by ZionXIX »
misha wrote: 10 Aug 2021, 07:34 Then no alignment needed.
I finished replacing the control arms and ball joints. 100% alignment needed. I suspect the unreported front end collision necessitated an alignment compensation. Now with new parts the steering wheel is 15 degrees to the left for straight driving and the passenger wheel has some visible toe out.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
I never had issues or needed alignment after control arms or bushings replacement.
It could be that somebody in the past performed alignment with bad and worn steering parts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
So, i have to change a control arm because a bush is broken. Under warranty.
Thanks to all of you Guys that transformed me from a pumpkin beginner to a respectable mechanic.
Volvo pumpkin.jpg (38.75 KiB) Viewed 428 times
