Pipe corrosion, odd bolt, extra bolts ? Topic is solved
Clemens
Has thanked: 473 times
Been thanked: 219 times
Re: Pipe corrosion, odd bolt, extra bolts ?
Post by Clemens »
The ones you have in there are the newer style replacement bolts. At least on my 94 that weird bolt you have are used instead of these regular bolts and they almost touch the timing velt. My theory is that they were supposed to keep the belt from jumping a tooth. Maybe the later p80s used regular bolts and therefore that weird long bolt was discontinued.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1505 times
Been thanked: 3818 times
I scanned the 94 and 96 engine fiches for that bolt with no success
Clemens
Post by Clemens »
How weird is that. I have one stuck in there to prove it...
Summer: 1996 855 R
Donor: 1995 854 10V
Could that bolt possibly be one of the three special bolt you use to attach the flex plate , then remove to attach the ten “ regular bolts
9995756
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
No - I would have remembered that.
I installed the bolt in the lower of the two holes in that guard, but it ended up about 2mm away from the timing belt. Just seemed weird so I removed it and installed a standard bolt. But if a pic could be posted of it in place, I might go ahead and use it. I just don't quite get the purpose. Seems that if the belt wanted to jump a tooth, it would hit that bolt and score / cut the belt. But like I said, I just don't get it.
1999 V70 GLT
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
I just did my timing belt tonight, and both of the bolts in the lower cover were those weirdo bolts with the long shank. 10mm head, I think. As soon as I removed them, I was reminded of this thread. They even had the bit of red looking compound on the threads.
Unfortunately, I chewed the head up of one of them a little. I didn't have the wrench on it straight, and it kept slipping off. They were harder to get to than I had thought. It's still in decent enough shape to do the job, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Can anyone find a part number fir these funny long bolts to document them here please
Sveedy
Post by Sveedy »
Well then I guess I'll pop it in one of the lower holes and call it good.
1999 V70 GLT
454cid
Post by 454cid »
abscate wrote: 22 Jan 2022, 03:19 Can anyone find a part number fir these funny long bolts to document them here please
You want me to find a part number, to a bolt??? I can't even find a cup holder, or a trunk light without help :lol:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
974674 ? superseded by 985031
Couldn't find a pic
