Pipe corrosion, odd bolt, extra bolts ? Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
The ones you have in there are the newer style replacement bolts. At least on my 94 that weird bolt you have are used instead of these regular bolts and they almost touch the timing velt. My theory is that they were supposed to keep the belt from jumping a tooth. Maybe the later p80s used regular bolts and therefore that weird long bolt was discontinued.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Been thanked: 4068 times
I scanned the 94 and 96 engine fiches for that bolt with no success
- Clemens
How weird is that. I have one stuck in there to prove it...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Could that bolt possibly be one of the three special bolt you use to attach the flex plate , then remove to attach the ten “ regular bolts
9995756
9995756
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
No - I would have remembered that.
I installed the bolt in the lower of the two holes in that guard, but it ended up about 2mm away from the timing belt. Just seemed weird so I removed it and installed a standard bolt. But if a pic could be posted of it in place, I might go ahead and use it. I just don't quite get the purpose. Seems that if the belt wanted to jump a tooth, it would hit that bolt and score / cut the belt. But like I said, I just don't get it.
1999 V70 GLT
1999 V70 GLT
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I just did my timing belt tonight, and both of the bolts in the lower cover were those weirdo bolts with the long shank. 10mm head, I think. As soon as I removed them, I was reminded of this thread. They even had the bit of red looking compound on the threads.
Unfortunately, I chewed the head up of one of them a little. I didn't have the wrench on it straight, and it kept slipping off. They were harder to get to than I had thought. It's still in decent enough shape to do the job, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Can anyone find a part number fir these funny long bolts to document them here please
- Sveedy
Well then I guess I'll pop it in one of the lower holes and call it good.
1999 V70 GLT
1999 V70 GLT
454cid
You want me to find a part number, to a bolt??? I can't even find a cup holder, or a trunk light without helpabscate wrote: 22 Jan 2022, 03:19 Can anyone find a part number fir these funny long bolts to document them here please
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
974674 ? superseded by 985031
Couldn't find a pic
Couldn't find a pic
- 10 Replies
- 2321 Views
Last post by mickjenkins
- 19 Replies
- 6192 Views
Last post by jadnhm
- 1833 Views
Last post by lcc014
- 2891 Views
Last post by ZionXIX
- 658 Views
Last post by pknapp66
