Engine rattling noise on V70 1999 B5254S (video) Topic is solved
Markus123
Year and Model: 1999 2.5 TDI
Has thanked: 2 times
Been thanked: 3 times
Post by Markus123 »
Hi!
Can you help me diagnose rattling sound on 1999 V70, 2.4 121kw (B5254S) engine. Removing serpentine belt did not help, replacing all 20 hydraulic lifters did not help also. Im thinking it could be rod bearing or DMF.
d703040e-206e-4552-826a-126a09841871.mp4
(4.63 MiB) Downloaded 47 times
Has thanked: 1505 times
Been thanked: 3818 times
It does sound like rod knock but it isn’t coming at the right place. Rod knock is worst when you lift the throttle.
Sorry, that the best I’ve got.
Markus123
Post by Markus123 »
abscate wrote: 08 Oct 2024, 05:43 It does sound like rod knock but it isn’t coming at the right place. Rod knock is worst when you lift the throttle.
Thanks, Im thinking also, sound like it, but not quite like it X D. Will drop oil pan this weekend and touch rod bearings and piston pins
Markus123
Post by Markus123 »
So, theres is some play on cylinder 2 rod bearing...
Markus123
Post by Markus123 »
Can I get away just replacing all rod bearings? What issues there may occur...
20241012_145936.mp4
(10.38 MiB) Downloaded 34 times
